63, 327_340, Edelbrock 4105 carburetor, non-electronic distributor with points, lt1 cam
I recently had a saga of "engine dies after warm up" that many of you participated in. That got solved by insulating the fuel line from the pump to the carburetor. Now I have another "engine dies" problem, but different circumstances.
After warm up, when in motion and the clutch is depressed for cornering or stopping, the engine will die. The engine will restart easily and idle well. If I am stopping and the engine starts to die, I can give it gas (fast footwork) and prevent it from dying, and once I am stopped it will idle fine. Someone suggested that I check the adjustment of the carburetor floats. I had occasion to do this fairly recently during the previous saga, so the float adjustment should be OK.
Any other ideas?
Steve
P.S. I checked the archives, but the only post I found with similar symptoms had TI distributor problems. A generalized Google search turned up a number of posts describing my same symptoms in several different more modern makes and models. And curiously enough, a neighbor with a Factory-Five GTM kit car, which is built with a C5 engine and drive train, has the same problem.
Any other ideas?
Steve
) This may save a lot of troubleshooting time.
