N11 off road muffler exhaust - factory finish - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Re: N11 off road muffler exhaust - factory finish
    Originally posted by David Kalaydjian (21729)
    Gents; I have a set of GM over the counter N11 mufflers and pipes on my 65 L76. I have the option of painting the mufflers black or leaving them natural metal finish. These a carbon steel units from roughly 1981… What was the factory finish at the time? Any input is appreciated.
    Thanks in advance.
    David-------
    Very low gloss black at least on the bottom of the mufflers.
      • 11608
      Eggshell or satin, not BBQ black. I always think that BBQ black is way too flat, and looks wrong. You don't need high heat paint, as I've found regular spray paints hold up just fine.
        • 15573
        My experience is that paint provides a poor facsimile of the coating that was originally used. The original material had a high build to it that resulted in a thick coating. Paint just doesn't have that thick appearance. You are, however, correct about the gloss level.
          • 11608
          I suspect that you could get close with a spray gun and the right paint, but few go to that level of effort. Since the vast majority of exhaust systems are treated under the standard deduction formula, paint or coating need not even be present.
            • 15573
            We need more points for the exhaust system in order to encourage TFP appearance. Where to take them from?
              • 11608
              Given that there has been some resistance to changing the sheets and scoring, I wouldn't hold my breath.
              I'm only allowed to change the sheets in the other organization.
              • Bob J.
                • December 1, 1977
                • 713
                I'll second what you said.
                On original midyear mufflers I've removed paint isn't the look .
                To me, it is asphalt based and the texture is like fine undercoat (not big and lumpy).
                Bob Jorjorian
                  Bob Jorjorian
                  Bob-------
                  That's what it is. One can purchase the "smooth" type undercoat in spray cans in auto parts stores. This might work well. I'm going to try it.
                  • Alan D.
                    • January 1, 2005
                    • 2027
                    Have tried the auto parts store undercoating - not overly impressed (better than paint). Just got a can of "LeakSeal" by Rust-Oleum, tried a little on the half shafts and one can get it to run in a thick blob similar to what is found on some old half shafts.
                    I still need to do a whole shaft once car is back inside for winter.
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      May look more authentic with roofing tar or driveway crack sealer both reduced a little. The process at GM was run out the end of a hose.
                      • Michael J.
                        • January 27, 2009
                        • 7073
                        I totally agree, I think they should be taken from the Exterior area and given to Chassis.
                        • Bob J.
                          • December 1, 1977
                          • 713
                          Michael
                          Yeah, take it out of exterior paint and add it to chassis
                          Bob Jorjorian
                          • John D.
                            • June 30, 1991
                            • 874
                            Whatever you put on wouldn't it have to be really thick to cover the embossed part numbers that weren't on the factory parts ?
                            • Bob J.
                              • December 1, 1977
                              • 713
                              Isn't that called cheating?
                              Don't give them ideas, John.
