C2 Fan Shroud Square J Nut Clips - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4232
    Someone asked me about the hardware for fan shroud at the Ontario Regional.
    PART # 62120
    This is the site of supplier
  • Michael M.
    • February 1, 1993
    • 603
    Re: C2 Fan Shroud Square J Nut Clips
    Gene, none of the pictures you posted look like the correct nut. I know the original nuts were a " U " nut for the fan shroud.
    • Alan D.
      • January 1, 2005
      • 2027
      Well not all C2 used the same hardware, do you have a GM part number? I perhaps have some references to those, also if used some place else that may help. And what year(s)! See 1965 Radiator shroud attaching clips below for some pictures
      • Gene M.
        • April 1, 1985
        • 4232
        Look at PART # 62120 it's 5/16 square nut projection welded on J clip as original.
        • Enzo C.
          • January 12, 2012
          • 533
          Here Are a few pics of the original J nut clips for 67 fan shroud.. I know that 65 are not the same
          Enzo Colosimo
          Ncrs Ontario Chapter Chairman 🇨🇦
          ENZ-Z06/67
          • David L.
            • July 31, 1980
            • 3310
            The "U" nut listed in the 1966 and 1967 Corvette assembly manuals (UPC 11-13, sheet A4) is GM # 3792259 and is listed in my vintage Chevrolet parts catalog in Gr. 8.143 with the description 5/16"-18 "J". According to Chevrolet Parts History GM # 3792259 was replaced with GM # 3958324 in May 1969.
            Dave
