Fan Clutch Rebuild & Repro Battery Recommendations - NCRS Discussion Boards
  • James B.
    • December 1, 1992
    • 281
    I am nearing completion on 3 1/2 year restoration of my '67 L79 Coupe. I need recommendations on two items:
    Fan Clutch- Three years ago I bought a "rebuilt" correct fan clutch. I stored it w/ bimetal strip upright. Put it on the car and within a couple of days it started leaking. Of course, I can't find the receipt or remember who did it (only would like to remember to insure I don't send it to him again!!). Can anyone recommend a reputable source for another rebuild? There was a guy at B Gold this summer who looked good but I didn't get his name, thought I was all set!
    Repro Battery- While I would like to use a repro battery to minimize point loss on judging I have had terrible luck with those batteries over the years (despite trickle charger & maintenance). Is there any brand/supplier who offers one close to original for the '67 that will last longer than a year?
    Will appreciate help and advice, Jim B
  • Russ S.
    • April 30, 1982
    • 2161
    Re: Fan Clutch Rebuild & Rero Battery Recommendations
    I thought the correct way to store clutches was bimetal down so oil don't leak out of the seal. ??
    • David L.
      • July 31, 1980
      • 3310
      The metal strip on the Schwitzer fan clutches is stamped "THIS SIDE UP".
      Dave
      • Mark D.
        • June 30, 1988
        • 2142
        Dan Kirkconnell is the man to restore your clutch.
        (813) 477-6217
        Kramden
        • Ken A.
          • July 31, 1986
          • 929
          Dave
          That has nothing to do with storage of the clutch
          • Russ S.
            • April 30, 1982
            • 2161
            Isn't that the direction as to which side is installed up?
            Dave
            • Ken A.
              • July 31, 1986
              • 929
              Yes, it only refers to the installation of the metal strip.
              • Gene M.
                • April 1, 1985
                • 4232
                Fan clutch should be kept in same position as if it were installed in the car.
                • Larry M.
                  • January 1, 1992
                  • 2688
                  (813) 477-6217
                  I agree. And Restoration Battery for your battery. Antique Auto Battery is the manufacturer of the batteries, and a supplier to Restoration Battery. Either one will get you a nice battery..............although I have been using Tom at Restoration Battery for over 20 years.
                  The current gel, reproduction batteries do not leak acid and should typically last you 5-8 years. My last one actually went 10 years.
                  Larry
                  • Ken A.
                    • July 31, 1986
                    • 929
                    Makes no difference how you store it. GM parts were not designed for any "special" storage.
                      Ken--------
                      • Ken A.
                        • July 31, 1986
                        • 929
                        Joe, nobody at the dealer parts department paid any attention to those stickers. Ken
                        • James B.
                          • December 1, 1992
                          • 281
                          Mark,
                          Thanks, I will call him.
                          • James B.
                            • December 1, 1992
                            • 281
                            Larry,
                            Okay, I see Restoration Battery in the Driveline. Didn't know they were gel now. I will try it.
                            Thanks, Jim
