Re: Help with camshaft selection for 350 SB
The primary difference between the L-46 and L-79 cams is the inlet POML, the former being 114 deg. ATC, the latter is 110 deg. ATC. The L-46 cam's additional two degrees .050" lifter rise duration is not significant, but what's interesting is that even though the inlet and exhaust .050" durations are 224 deg., they are actually different lobes with slightly different lifts and dynamics. Chevrolet optimized the dynamics for the differing masses of the inlet and exhaust valves!
The above is why I recommend the L-46 cam for L-79 restorations, but installed four degrees advanced to equal the inlet POML of the L-79 cam. Installing it at the as-manufactured inlet POML will reduce low end torque and increase top end power, but that additional top end power on the short stroke 327 may be beyond lifter pump up speed, especially with massaged heads.
Later indexing is better for long stroke engines. In fact I recommend installing a L-46 cam retarded four degrees for a 3.75" stroke configurations, and with typical OE induction and exhaust systems, it should make useable power to about 6000, and the long stroke/large displacement yields plenty of low end torque.
