What causes the speaker to "pop" when you turn the radio on? Also, are there different speakers for cars with a/c? Can they be rebuilt if original? What to look for? Ohms?
Radio speaker "pops" when I turn it on.
Re: Radio speaker "pops" when I turn it on.
John,
Not sure of your description of "pop" when you turn the radio on - a pop to you may be a loud static - which occurs when the internal components of the volume control on a C2 radio becomes dirty. On the other hand you very well may have a "pop" caused by an electrical surge. Is the sound coming through the speaker or from inside the radio or some other location? That will help identify the possible cause. What ever you do, DO NOT spray electric contact cleaner or WD40 or something like that into the volume control device - you will ruin it for good.
As for correct speakers - don't know if an AC car has a different speaker - but even if it does, the most important thing is to get a speaker that is matched to your radio. For more on this subject see this website - http://electrodesign.us/index.htm. Jerry Rudbeck is one of the best C2 radio guys alive today. Unfortunately, he is taking a breather from radio repairs but there is a lot of good info on his website.
Hope this helps.Ed- Top
How was the picture of the battery cut-off I posted for you???
- Top
John,
Hope this helps.Leif
Top Flight 2017 Lone Star Regional- Top
Jerry Rudick restored my 66 coupe radio. The crackle or static sound when you turn it on is not the speaker, it is the radio. I can't remember how Jerry described the cause, but he said it would do more harm to try and clean the on/off/volume assembly with any electronic or other aerosol cleaner. I don't have my radio working in the car yet, but he said whatever he does to restore the part may last forever or for a week. The only way to really fix it was to replace the part (I can't remember what it was called) with an NOS one and that they are far and few between and very expensive.
If you do decide to replace the speaker with aftermarket, the only one Jerry recommended is at the link below. Scroll down about 3/4 of the web page and you will find a listing for 1958 - 1967 Corvette Speaker
http://www.turnswitch.com/speakers.htmDon Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
I also have a 67 convertible and the radio does the same thing. It crackles and pops when I turn it on, but one I get it to the desired volume the cleans up and work fine.
DonDon Harris
Leif,
I had my radio repaired by Jerry Rudbeck - it came back looking and performing as good as, if not better than new. In addition to giving me a detailed breakdown of what he did to it, he also send me a short note with recommendations to keep it operating in great shape. One issue that is common to mid 1960s GM radios is the design of the on/off & volume control. It contains a stack of small carbon disks that have a tendency to corrode - and get dirty - that is what causes the static when you turn the knob. If you use WD40 or similar products it permanently damages the disks. Jerry recommended using a spray product called DEOXIT - designed for cleaning electric contacts. It is an aerosol and is cost about $15 for a small can.
If you go to Jerry's website (http://www.electrodesign.us/corvetteradioinfo.htm) and click on "Corvette Radio Info & FAQs" he addresses the scratchy volume control issue towards the bottom of the page. The referenced web page does not mention DEOXIT - but he did recommend in to me in e mails and in a note he included when he returned my refurbished radio.Ed- Top
Ed,
Thanks for the heads up. Mine has the same "crackling" sounds when I first turn it on but only when turning it on. I'll try to find some DEOXIT.
Edit: Just Googled it...Radio Shack carries it. Also, available online thru Amazon.Leif
This is what the internals of the on/off volume control look like. It's practically impossible to properly clean it from external access.
I repaired this one. Not easy, but doable. I sent these pictures to Jerry then and may have to use my method some day. The final reattach method is silver solder as the intenal tabs must be broken to extract the switch from the gang assembly.
As usual, picture heavy.
- Top
Richard, that was one nasty switch. Did you also go further and clean up the volume control potentiometer located on the same shaft???- Top
Stephen, I didn't touch it as it worked fine when I got the radio turned on with a jumper wire across the switch terminals when diagnosing the radio. All before I pulled the switch assembly out of the case.
Rich- Top
Are talking about this stuff from Radio Shack? Where exactly did you spray it? Was the radio out of the car?
JohnAttached Files- Top
