Guys,
im installing my PS cylinder and i had a couple of questions. Even though I had ordered a new cylinder a couple of years ago I had to order a rebuild kit because I had replaced the boot that goes over the center link connector. My questions are:
is there anything else that goes on that connector part other than the boot? I'm referring to the cork or felt washer that is included in the kit. It seems as thought it might be for that area. Also, the new cylinder came with hardware to connect it to the frame mount but the hardware in the rebuild kit is different. The rebuild washers are bigger and natural finish compared to the zinc finish of the hardware that came with the cylinder. Which ones are correct?
Ive attached a few photos if that helps.
Mike
Mike
