have a 63 stock hi horse 327 fuel injection car with a dead skip on cylinder 4. 155 psi compression springs appear ok and lift appears ok no measured at this time cap wire and plug ok. if the sealing gaskets at the bottom of the injector are in poor shape will that cause a vacuum leak not sure if I am having an injection problem cyl 4 only any ideas Thanks steve
