Removed some shoulder belt retractor reinforcement plates for restoration. Was about to put them back in and discovered that the rivet holes were all .205 to .209 diameter. But it apparently calls for a 3/16" diameter (.1875) rivet. Nothing else under the car has had holes so much larger than the rivets. Is this too large for the rivet to grip? Before removal, I noted that the top two rivets had failed on each side, but the bottoms were still holding.
3828548 rivet for 3966707-8 retractor reinforcement
Re: 3828548 rivet for 3966707-8 retractor reinforcement
Yes. 72 The hole in the steel part is quite larger than the rivet. And its not like its rusted out or anything, just drilled much larger than expected and since a couple of rivets failed probably decades ago, I was concerned. It fits over a compound curved surface and doesn't sit perfectly flush up against the body so its going to be under tension anyway. Wonder if anybody else who has reinstalled these parts has noticed the same thing.- Top
Use a rivet that is a little longer than you would normally use, put enough pressure on the bracket to seat it as much as possible and start slowly(if using a air gun) to peen over the head making sure your riveting tool stays on center. The rivet will then fill the extra large hole in the bracket and still have a nice large peened head.- Top
Thanks, I've ordered some longer rivets.Use a rivet that is a little longer than you would normally use, put enough pressure on the bracket to seat it as much as possible and start slowly(if using a air gun) to peen over the head making sure your riveting tool stays on center. The rivet will then fill the extra large hole in the bracket and still have a nice large peened head.- Top
