1977 hvac issue - NCRS Discussion Boards
1977 hvac issue
  • David B.
    • September 21, 2016
    • 2
    1977 hvac issue
    the heat and air is only coming out from the floor ducts. no air is coming out of the other vents or the defrost.
    • 6940
    Re: 1977 hvac issue
    David sounds like a vacuum hose under the hood may have been disconnected or feel off. this system operates on vacuum.
      Re: 1977 hvac issue
      David------
      In addition, it could also be caused by failure of one of the system's vacuum actuators or the rotary switches in the system controller in the forward console.
      • David B.
        • 2
        Re: 1977 hvac issue
        thanks, I will look into those suggestions. how many actuators are there and where are they located?
          Re: 1977 hvac issue
          David------
          The actuators are located underdash on the heater box. I believe there are 2.
