Re: 1966 C2 Rear Spring Height - Am I too High?
Bob, Unfortunately, nowhere in the Service Manuals is the procedure noted regarding ensuring the full weight of the car and a roll-out performed before torquing the 4 spring bolts. By applying full weight, the entire spring assembly will then lay more flat up into the carrier perch.
The torque spec is outlined in the AIMs and CSM's, and IIRC is 55-75 lbs/ft. I like to keep it on the low end typically. I always fear these bolts and fortunately my fear has saved many carrier covers and cases. As Bob mentioned, just get them snug with a wrench to start.
Larry also brings out a important aspect regarding the forward 2 spring attach bolts where they thread into the carrier case. Make accurate measurements checking assembled spring thickness, spring plate and even lockwasher thickness. Check the threaded carrier depth and lengths of bolts before attachment. Cut the bolts if necessary.
This post outlines a case where I had to cut bolts, using original bolts after restoring a original spring using new liners.
https://www.forums.ncrs.org/showthre...355#post765355
I also had the same issue recently using reproduction bolts with a reproduction spring. I had to cut the tips of the bolts apx 1/4".
Rich
Rich
