1970 350/350 Radiator Installation Diagram Help - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    Where can I find an installation diagram for a 1970 350/350 with air conditioning? I did not see it in the AIM. Thanks.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1970 350/350 Radiator Installation Diagram Help
    The radiator installation is the same as the LT1. Copper radiator and core support is the same. Auto trans uses a little different radiator, but basically the same. The A/C components bolts in front of the radiator. That will be in the C60 section. Just follow the LT1 radiator info in AIM, you should be ok.
    Gary
