1964 FI Roadster
Re: 1964 FI Roadster
I've seen pictures of original 64 FI cars with '175' pumps, none with '326' pumps. Personally I think '175' pumps were a production line pump, service replacements were '326' pumps, as they became available in early 65 model run. Think the TIM&JG might need an update. Be careful, EBAY vendors are selling later recast '175 Truck pumps as 'Corvette Pumps'. Real ones are RARE !!!!1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
I have original '64s with the 326, it is in the TIM&JG for a reason.I've seen pictures of original 64 FI cars with '175' pumps, none with '326' pumps. Personally I think '175' pumps were a production line pump, service replacements were '326' pumps, as they became available in early 65 model run. Think the TIM&JG might need an update. Be careful, EBAY vendors are selling later recast '175 Truck pumps as 'Corvette Pumps'. Real ones are RARE !!!!Big Tanks In the High Mountains of New Mexico- Top
How would you explain the print date?
Bob Jorjorian- Top
Wayyyy too long a discussion that has been had many times before and convinces no one. I'm not going there again.Big Tanks In the High Mountains of New Mexico- Top
HI Patrick, Gorgeous engine for sure. I did not read all the posts (as usual). Here's what I noticed on the fuel injection. I wish I could have blown up the air meter side bigger so I might be incorrect on washers.
Air meter to Plenum. Has 4 of 5/16 split lock washers. They should be blackened
Choke cover. The 3 of 8-32 x 5/16 slotted fillister screws should be blackened.
Bellcrank to bellcrank stud. The retainer should be blackened.
You identification tag-should be painted of course.
I tell customers to never install the triangle inspection tag on the FI unit untl the car is 100% restored as they bend so easily. So nice to see it's off. I always thought they went on the 12:00 position but do like the 6th edition which I believe says 10:00 or 12:00. Put it on the 10:00 later to keep it from bending. Repro tags typically get a one point hit.
Fuel meter shield is missing but if going on a dyno you don't want it on now anyhow for adjustments.
Hose clamps-The slotted screws-go toward the firewall side. Good luck with the resto. John D- Top
Not sure if fuelies in 64 had the crayon marks, my 365 had RE in yellow lumber crayon on the head passenger side rear facing the firewall in yellow....similar to the photo of this 65
Attached FilesDino Lanno- Top
Indeed '64s did. Here is a picture of my low mile original '64 L84, as the engine was pulled for the first time to be restored. The "RF" and job sequence number are on the back of the heads. However, much effort is needed to preserve them as the engine is restored and painted, it is shown above in my post #2. My restorer was able to preserve them, so as with much of the car, original marks and such (like outside passenger side footwell and rear bulkhead markings) are all still in place from the factory.Big Tanks In the High Mountains of New Mexico- Top
Thanks JohnHI Patrick, Gorgeous engine for sure. I did not read all the posts (as usual). Here's what I noticed on the fuel injection. I wish I could have blown up the air meter side bigger so I might be incorrect on washers.
You have been a big help with the restoration. Scott Pfuehler restored the fuel injection unit with your support. I have the shield and will install it after we calibrate the fuel injection unit after the dyno run. I plan to order an injection tag in the next week to install later. Will check the blackened components.
Pat- Top
Looks really nice, nothing obvious jumps out, but three questions, why didn't you paint the exhaust manifolds engine color, what serial number is your FI unit, and do you have a VIN stamp on the FI unit? Thanks, here is a picture of mine that just went in my '64 tanker.
Michael,
I got your PM. Glad you enjoyed the articles. Just writing part 8. Perhaps you should do the same with your 64? I would certainly be interested. I am getting ready to video the dyno test for our OK-NCRS in the next couple of weeks. How much power do you think it will make? I am guessing about 310 hp on the dyno. We shall see.
Pat- Top
If I wasn't such a terrible writer, I might consider that, but not sure if any of my chapters would be interested. I am having mine tuned on a chassis dyno, and I will be very disappointed if it is less than 310 HP at the rear wheels. If you are using an engine dyno (which it sounds like you are), I would expect north of 350 HP if your engine gets the best tune on the FI unit and is stock configuration. That's my guess.Big Tanks In the High Mountains of New Mexico- Top
Michael, we shall see with race gas and lots of advance. My engine builder thinks it will be around 320 to 330hp. He has done a number of FI engines and a lot of corvette small blocks. Im a bit more pessimistic. We plan to run it for 45 minutes before we make any pulls. Stock mechanical 30/30 cam.- Top
