Has any of the owners of 54s had a issue with continuios loosening of hubcaps. Mine begin with rotating slightly and bending the valve stems.Than if the problem is not addressed quickly, they will come off. I have the wheels with the nubs however that doesn't seem to help. Any one have a cure?
1954 Hubcaps
Re: 1954 Hubcaps
The problem of the wheel cover auto-rotating slightly isn't unique to '54s. The wheel covers on my '60 do the same thing. I have no idea why it happens. I just bite the bullet and reposition the covers every so often.
Jim- Top
Re: 1954 Hubcaps
While my 54's never had this issue I remember a 62 that did. If I recall I bent the tabs ever so slightly so that there was a more aggressive hold on the wheel. The hubcap went on with more effort but that solved the issue for me. Hope that helps.- Top
Re: 1954 Hubcaps
John, I read your post from over a year ago. I had exactly same problem on my 55 and installed steel valve stems which solved the problem. They won’t bend like rubber stems and prevent the cover from rotating.Has any of the owners of 54s had a issue with continuios loosening of hubcaps. Mine begin with rotating slightly and bending the valve stems.Than if the problem is not addressed quickly, they will come off. I have the wheels with the nubs however that doesn't seem to help. Any one have a cure?- Top
