1967 coupe rear window stainless and interior moulding around rear glass - NCRS Discussion Boards
  • Michael A.
    • June 30, 1986
    • 68
    Hi All,
    Been sometime since I posted on the site. Just purchase a 67 coupe to drive and it seems to have some loose trim inner and outer on the rear window. Never had any issues like that on my old coupe. Thought I would ask for some advice before removing and trying to figure out how to tighten it up. Would appreciate any help I could get with this issue. Please tell me where to look or give me a call with advice.
    Thanks Mike (317)729-2418 fleagle14@embarqmail.com
  • Keith B.
    • September 15, 2014
    • 1575
    Re: 1967 coupe rear window stainless and interior moulding around rear glass
    I would think if you can't tighten down the screws then the fiberglass behind the trim the screw holes are striped out. There are many ways to fix them. I like to fill the holes in with epoxy. Let it dry the drill a small piolt hole and then you can tighten down the proper screw
