Installing sending unit on new tank in 64. I see the o ring fits nicely between the tank and unit. The sending unit also came with a cork gasket. The AIM doesn't show where the gasket goes. It appears there would be a good seal with the o ring. Is the gasket supposed to go between the o ring and unit? Doesn't seem likely but want to be certain. I don't want to mess with a gas leak. Thanks! Michael Kalogridis 518 248-1105
Sending unit o ring or gasket.
Tags: None
- Top
Re: Sending unit o ring or gasket.
Prob worth changing the filler neck gasket too though....especially if you're getting a gas smell...
On my 63 the filler neck mounting screws have integrated rubber O rings that go bad too...you'll want those if a '64 uses 'em...Attached Files- Top
Frank and Michael------
I like cork for lots of things but not for the filler neck gasket even though that's what was originally used. I make up a similarly configured gasket from a sheet of about 3/32" thick buna-N material.
The screws with integral rubber seal, GM #3767804, were used for all 1963-74 Corvette filler necks. They are essential and the seal must be in good condition.In Appreciation of John Hinckley- Top
Ethanol%20&%20E85%20Material%20Compatibility.pdfFrank and Michael------
See top of page for link. Was having trouble getting this to post.- Top
[ATTACH]73240[/ATTACH]
In checking out Buna-N, I found this disturbing document regarding Ethanol compatibility. According to this, many of the components in our fuel systems are not compatible like brass, tern plating, and cork. Sorry I looked, but it explains a lot of things I have been seeing. Dan
Dan------
I made my filler neck gaskets prior to the advent of ethanol-blended fuels. However, I think the compatibility problems with ethanol are likely based upon straight ethanol or gasoline with a high percentage of ethanol (like E-85).
In any event, the Buna-n is better than cork as far as ethanol compatibility goes. Actually, I'd prefer to make the filler neck gasket from a sheet of Viton if I could find it.
GM has approved the use of gasolines with up to 10% ethanol for all of its vehicles going back quite a few years. However, I don't know just how far back this approval goes. Finding widely available gasolines not blended with up to 10% ethanol is becoming increasingly difficult in some areas of the country. In California, it's virtually impossible.In Appreciation of John Hinckley- Top
Dan------
I bought mine at an industrial supply company which specialized in elastomers but it was a long time ago and I don't recall the name of it. I think you can probably find it online. Buna-N is a VERY widely used material, especially for fuels and lubricants. Grainger might be one firm that could supply it.
By the way, I did a little online research since I last posted and I did find Viton sheet material. The problem is that a 36" X 36" size piece (the smallest available) of 3/32" thickness costs almost $500.In Appreciation of John Hinckley- Top
The "O" Ring Store has small sheets of Buna N...!Attached Files- Top
Gary-----
That sounds better. A 12" X 12" would be sufficient for me to make the filler neck gasket + several other fuel-resistant gaskets I might want to. This might be worth 70 bucks. While I might be crazy enough to spend this kind of money for a few gaskets that probably amounts to extreme "overkill", I really think that the Buna-N is completely sufficient for the filler neck gasket.In Appreciation of John Hinckley- Top
In checking out Buna-N, I found this disturbing document regarding Ethanol compatibility. According to this, many of the components in our fuel systems are not compatible like brass, tern plating, and cork. Sorry I looked, but it explains a lot of things I have been seeing. The title "Ethanol Fill up Feel Good" gave me a laugh. Dan
Duke- Top
