I was replacing a rebuilt rear trailing arm on my 1969 with automatic transmission. I put it in neutral to get the axle drive shaft to spindle bolts into position and then put it into park to torque them. The first three went fine. When walking behind the car to move the fourth into position I noticed that the back up lights were on while the car was in neutral. Then when I tried to torque the fourth bolt, just as the wrench clicked the spindle slipped. It now turns almost freely as I turn the bolts.
I'm thinking (hoping) this is a transmission linkage vs. a transmission issue. I am going to start doing some research but wanted to check here and see what people think. Any advice would be appreciated. Thanks.
