What size are the cotter pins?
The 70 AIM calls out the same part number 103385 1" x 1/8" for the upper and lower ball joint cotter pin.
However, I have an NOS lower ball joint and the cotter pin is longer at 1"-1/2" x 1/8" diameter.
If I labeled the cotter pins correctly when I took the front suspension apart they both appear to be 1-1/8".
While the ball joints were original I have reason to think at least one of the two front spindles were removed at one point.
The reason I say this is the upper ball joint cotter pin was not installed as shown in the AIM.
Thank you,
Bill
Thank you,
Bill
