327/350hp - reinstallation of aluminum oil filter plate/ad in oil filter recess area - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    hey ...
    quick question.
    the aluminum adapter piece that is bolted to the block in where the oil canister screws into --
    1. is there a gasket between it and the machines block area?
    2. the high pressure relief valve - how is it oriented in the pocket (what direction should it point).
    machine shop disassembled the engine and did not install that part
    thanks
    bill
    • 43193
    Re: 327/350hp - reinstallation of aluminum oil filter plate/ad in oil filter recess
    Originally posted by Bill Chamberlain (47576)
    hey ...
    quick question.
    thanks
    bill
    bill------
    A gasket between the bypass valve assembly and block may have been used on some 1967's. I don't think the use of this gasket is absolutely necessary but if you want to use one it certainly won't hurt anything. The GM part number was GM #3903322 but it's long-since GM-discontinued. However, Dr. Rebuild offers a perfect reproduction of this gasket if you wish to use one.
    The orientation of the valve assembly is not important. You can install it in either of the 2 possible positions.
    • Bill C.
      • July 15, 2007
      • 904
      thanks Joe --
      just wanted to check before mounting the plate.
      Bill
