After some consideration and eyeballing , I decided my front top door gap is unacceptable .
I figured that either adding a shim at #1 mount , and or removing one at #2 mount would do the trick .I also did some archiving for tips and confirmation.
I came across this post and it has me baffled. I can find no place where the radiator support connects to the frame ! So before I start , and or ruin something, can someone tell me what I am missing ???
Jim
Russ Steinhaus (5540)
Join DateApril 30th, 1982Posts1,430
Re: 67 Roadster door gap
Jim
If your door gap and height is good at the rear (but wide at the front top) then you would add a shim at the number one body mount. (convertible) However, if you are going to add or subtract shims at the number one mount you need to have the radiator support to frame mount bolts loose as the front end will go up or down depending on whether you are adding or subtracting shims at #1. If you are removing shims at number one then be sure you remove two at the rad. support to allow the front to come down. You may or may not need to replace one of those two when you are done adjusting the door gap. PS If you do add a shim at number one mount, then the rear of your door will drop making it necessary to readjust the door which will return the rear of the door height and gap to where it was before you started while closing the too wide of a gap at the front top of the door.
Last edited by Russ Steinhaus (5540); March 5th, 2016 at 09:34 PM. Reason: addition
