Winch - NCRS Discussion Boards
Winch
  • Glenn B.
    • June 4, 2008
    • 76
    Winch
    Thinking about an electric winch for my trailer, anyone tried the ones from Harbor Freight?
    Glenn Butler
    49107
  • Gary S.
    Super Moderator
    • February 1, 1984
    • 456
    Re: Winch
    Just put a 4500 Traveller from Tractor Supply in my 24 ft enclosed trailer two days ago. Easy install, 47 feet of cable, 6 ft remote cord, just bolted power cables to my garden tractor battery, works smooth, lots of power. Has 30 day no questions asked return warranty. Think it cost $160ish. But made in China. Would be nice if it had remote cord long enough to reach end of trailer.
    Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
    • Jim L.
      • September 30, 1979
      • 1805
      Re: Winch
      I wouldn't cheap-out on a winch. When you need it, you really need it. You want to have a high quality winch in your trailer.
      And note that the rated pulling force of a winch is measured/specified with a completely empty spool. As the spool fills with cable, the actual pulling ability goes down. Take away: Buy a higher rated winch, much higher in fact, than you think you need.
      Jim
      • Stephen L.
        • May 31, 1984
        • 3148
        Re: Winch
        I installed a SUPERWINCH S4000 in my 24 ft enclosed trailer.It's been in use since 2005, with NO problems.
        I winch my car in/out each time, as I elected to NOT install an "escape" door in the trailer. It makes it easy to load to a repeated location as I don't change the rear tiedown lengths. I just hook the tie downs into the hole in the frame just ahead of the rear wheels when the car is partially in the trailer. I then finish winching the car into the trailer until I've pulled against the rear tiedowns. Then I tie down the front and the car is positioned for best towing.
        I did extend the control wiring using a 3 conductor extension cord (cut the plugs off) which I installed by removing the old cable and replacing.
        I mounted an automotive 12v battery in the trailer for power. I wired the battery into the trailer wiring so that the battery is charging as I drive down the road. The battery also serves as the e-brake power source.
          • April 1, 2000
          • 477
          Re: Winch
          Like Stephen, I have a Superwinch brand that I'm happy with. I'd also agree with not "cheaping out" and getting something name brand. I know the Warn brand is very popular with the off-road crowd and they have some pretty extreme use cases.
          The other thing I did with mine was to mount it on a 2" receiver hitch insert plate. I then had a mating 2" receiver hitch receptacle mounted on my trailer, another one mounted on my 4 post lift, a 3rd one mounted to the floor of my garage, and obviously the winch could be "plugged in" to any truck/RV/whatever that has a receiver hitch. That way the winch is portable/modular and can be used in many different useful applications. Very handy.
          To answer your specific question, my brother-in-law bought one of the HarborFreight winches and has used it several times without complaint.
          • Glenn B.
            • June 4, 2008
            • 76
            Re: Winch
            Thanks to ALL, Stephen, nice set up & 67!
            Glenn Butler
            C-2 67
            • Bill M.
              • 1317
              Re: Winch
              I would not recommened anything electrically operated from Harbor Freight.
