Here's a question that I'd appreciate some clarification on. What is the difference between the 3711268 (55-62) cast thermostat housing vs the later 3827369 cast housing used on the 63 and up low hp cars?? Other than the numbers, they appear the same from what I can tell from the pictures. According to my GM parts book from the early 80's, apparently 3827369 was the number used for BOTH applications. So why the need for a different part number?? I also noticed that some of these housings don't have EITHER part number stamped on them, just "GM" and that's it. Thanks in advance for your replies, Dan.
