My power steering pulley is wobbly and I was looking to replace it. The part is discontinued and I can only find one on ebay for $250. GM Part No. 10227069. Is there any other gm part that will replace this. ANY OTHER IDEAS ON A REPAIR OR REPLACEMENT? This is just a daily driver and it seems my only other option is an aftermarket replacement - Billet Specialties FM1035PC - 6-Groove Power Steering Pulley.
1994 LT1 power steering pulley wobbly
Re: 1994 LT1 power steering pulley wobbly
Give these two a call. They maybe able to help you out.
- Top
Thanks Ken. I guess I need to improve my search skills. I was able to actually purchase one here in Houston for Carney's Corvette with the pump. His advise was not to pull it from the pump, as that is how it gets bent. So I am reinstalling the new used pulley with the pump hopefully it won't wobble.
Thanks again.- Top
Good to hear. I like searching for stuff it keeps my mind sharp.
Ken- Top
Thanks again.
Jim------
They get bent only if a proper puller is not used to remove the pulley.In Appreciation of John Hinckley- Top
they also get bent when removing the water pump bolt and not watching how fare out your ratchet is moving before it gets to the pulley if you don't go though the one hole. Don't ask me how I know... its been bent for nine years with no ill effectsThanks Ken. I guess I need to improve my search skills. I was able to actually purchase one here in Houston for Carney's Corvette with the pump. His advise was not to pull it from the pump, as that is how it gets bent. So I am reinstalling the new used pulley with the pump hopefully it won't wobble.
Thanks again.- Top
