1960's P/S control valve - NCRS Discussion Boards
    Re: 1960's P/S control valve
    Originally posted by Timothy Barbieri (6542)
    Joe,
    Could it be that GM did not include the 581 gasket in the overhaul kit because they thought it was reusable.
    Timothy-------
    That could very well be. However, if that's what they thought, they were wrong.
    • Harry S.
      • July 31, 2002
      • 5258
      I took the valve apart. Nothing has been cleaned yet except the ball stud and that needs to be replaced. It is rough not smooth.
      Joe, I assume the spring on the right is the Corvette Spring?
      • Jeffrey S.
        • May 31, 1988
        • 1879
        #18
        Harry,
        Could you measure the 2, 12 point bolts (thread size and length) and post here? Also, is that a split lock washer on these? Thanks for your help.
        Jeff
        • Harry S.
          • July 31, 2002
          • 5258
          #19
          16 x 1", only threaded for 1/2 inch. Yes, lock washers. All black phosphate.
            #20
            Harry------
            Please measure the free length of both of the 2 coil springs.
            • Harry S.
              • July 31, 2002
              • 5258
              #21
              Joe
              Right = FL - .7625 OD - .4670
              Left = FL - .5565 OD - .8770
                #22
                Joe
                Harry------
                Yes, the spring on the right is the Corvette spring.
                • Harry S.
                  • July 31, 2002
                  • 5258
                  #23
                  Harry------
                  That is what I figured the answer would be. I'll look for a rebuild kit that includes the stud ball and the two cups. When I take the replacement apart next spring I'll let you know what is in there.
                  Cheers.
                  • Jeffrey S.
                    • May 31, 1988
                    • 1879
                    #24
                    Harry,
                    Thanks for the response. I think you mean 3/8 x 16 x 1" right?
                    Jeff
                    • Harry S.
                      • July 31, 2002
                      • 5258
                      #25
                      Originally posted by Jeffrey Salz (13182)
                      Harry,
                      Jeff
                      Yes, 3/8 is good.
                      • Jeffrey S.
                        • May 31, 1988
                        • 1879
                        #26
                        Harry,
                        Thanks again for your help!
                        Jeff
                        • Timothy B.
                          • April 30, 1983
                          • 5177
                          #27
                          Harry, FWIW I overhauled the valve on my 63 a few years ago and got the kit from corvette stainless steel brakes in Miami and had no leaks or problems. I can't remember the gasket Joe refers to so I must have reused the old part.
                          • Harry S.
                            • July 31, 2002
                            • 5258
                            #28
                            Tim, did the kit contain everything pictured? There is a few extra O-rings for the later version of valve.
                            • Ray K.
                              • April 30, 2005
                              • 401
                              #29
                              Harry,
                              Is there any type of marking(s) on the 12 point bolt head? Can you post a couple of pictures of them?
                              Thanks.
                              Ray
                              • Harry S.
                                • July 31, 2002
                                • 5258
                                #30
                                Originally posted by Ray Krawczyk (43777)
                                Harry,
                                Thanks.
                                Ray
                                No headmarks, the top of the bolt is concave. The valve is now packed up.
