1962 Windshield assembly installation
I completed my windshield restoration and all went well with the help of some great NCRS members....thank you! the question how should I move forward, my thought is I should mount the windshield into the body with the rubber center gasket in place but without the shims, then mount the door posts in the bare doors, and check alignment and then slip the shims in as necessary to get the alignment correct....is that how it's done?
Dino LannoTags: None- Top
Re: 1962 Windshield assembly installation
If you are going to use a hardtop I would recommend mount the windshield to fit the bolted down hardtop.
I usually start with 2 end shims at each end of the windshield.
Then check the door posts and adjust adjust them to meet the installed windshield.
If you then install a soft top the top frame can be adjusted.
I am no expert but I am sure others will provide more info.
Bruce B- Top
Yes as Bruce suggested, I usually start with 2. I cut slots where the 2 studs locate in the sides of all shims so I can add or remove as needed.
But one other suggestion....
It will be best to install the defroster bezels before you install the assembly to the car. You can do it later but much more tedious to trim out the holes and angle them into position.
ALso, if you're alone, you may want to install the washer nozzles and cowl vent hinged assembly before w/s as well. This way you can reach over the dash with one arm to hold things while the other is under the dash for tighten-up tasks.
Rich- Top
All good advice, I assume you've glued that front flap down into the windshield channel.
And, if you have original tabs on the pillars (not the reinforced kind) be gentle rocking the windshield back and forth while working it into position.- Top
I put a 1/4 inch bead of black (Dumb dumb) next to the rubber seal under the WS frame, flattened part under weather strip, be sure to have some under seal. I also put a 1/8 inch bead between WS frame and rubber seal. Put tape on studs to keep them free dumb dumb. String on studs will help line up the holes.- Top
Windshield looks great. Before you drop it in place make sure the vinyl is rounded at the edge where it drops into the windshield channel - not being rude - but it looks as though the vinyl at the edge has a crease up before it drops in. Any "uplift" in the vinyl can make the weatherstrip look funky on the interior. Make sure you heatform the vinyl at this edge and roll it into place. If you haven't heat formed it - take a piece of scrap and learn the melting point on the work bench not on the car. All of the above advise is accurate, but most importantly 3 people to install - 1 upside down and one on each side of the assembly will save your paint!- Top
Thanks, I also have that on my list of future projects. If I remember correctly I read somewhere that it is critical to pre-fit the windshield assembly prior to body paint. Is there a document or guideline out there that has been made for ts to get the fit right?- Top
The most common fit issue on installation is the fit of the lower stainless trim spacing to the body. Usually it's close to the body at center and as it arcs outward towards the sides there is more gap to the body.This is common. You can fill with strip caulk or a non hardening sealer, but that can get messy later.
Rich- Top
Eric, There may have been discussions about test fitting post studs and T-bolts to holes in body but I've never had issues with fit on a C1 body unless there was major reconstruction of the nose/top surround and/or dash.
Rich- Top
Anyone have an explanation for this common problem of the gap between the lower trim and the body? The trim fit perfectly before removal. And what corrective action can be taken? I'm sure the OP would appreciate some insight on this potential problem. And yes I would too.
I've never considered using original seals to combat this issue as I see so many cars with different levels of "gaposis".
Rich- Top
Eventually, I just sucked it up and applied black butyl along the gap crammed into place with a popsicle stick. It didn't look awful but nothing like the original tight fit. That seemed to stabilize the gap. The picture shows how the gap eventually widened before I sealed it with the butyl.
A long-winded way of saying that I don't know if there is a real, permanent cure for the problem....on a 'driven' car..Attached Files- Top
