pulleys - NCRS Discussion Boards
pulleys
  • Martin M.
    • November 1, 1979
    • 124
    pulleys
    I need pics of 340hp Crankshaft pulley I have a box of pulleys. JM is not clear to me.
    Marty
    Beautiful Pahrump, NV.
    No smog, no rain, no winter, no hurricanes, no tornadoes,
    no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
    vetteheads.com alumni, Boston MA alumni
    1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
    1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
    1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
    1957 Chrysler 300 C 392 Hemi Car
    All for sale - most not cheap!!!
    Re: pulleys
    Marty
    Marty-------
    The original crankshaft pulley for your application was GM #3766987. This number should be stamped on the pulley so it's easy to identify. This is a 2 groove deep groove pulley of 6-3/8" OD.
    The GM #3766987 pulley was discontinued in April, 1964 and replaced by GM #3858533 which is very similar and will replace the 3766987 perfectly. The 3858533 is usually stamped with that number.
    Now, a question for you.......is the prime rib any good?
    • Martin M.
      • November 1, 1979
      • 124
      Re: pulleys
      Joe, THX for the response.
      Prime Rib is good, lots of other good food here BBQ, THAI, Chinese Buffet, a good steak house in the Nugget.
      Marty
