At Frisco it was pointed out to me that my 1970 did not have the door-ajar rubber pads installed. I'm not sure my car ever had them? My door-ajar switches operate correctly without the pads.
The new TIMJG pg. 31 says. "Glued to the lower rear of the door on some 1970 to 1972 Corvettes is a small gray rubber pad...................It contacts the door-ajar switch if door alignment requires a spacer to operate the switch".
So how much is some, 10%, 50% or 90% of the cars built? Do most cars have them or not?
Would you believe I once got dinged for HAVING the pad shown in the photo? That same exact pad, too.
