This car had the most butchered under hood harnesses I've ever seen, so I replaced everything under there with new harnesses. It's a '66 L79 NO TI. On the engine harness that goes across the cowl, there is a double pink wire that comes out of the harness. It obviously goes to the coil. Further back toward the master cyl there is a single pink wire, which I would assume goes a the ballast resistor, although the laminated wiring schematic I have isn't real clear. So if the single pink goes to one side of a ballast resistor, what goes to the other side of the resistor? All wires at the starter motor, including the ground are connected properly and I don't seem to have anything else under the hood to go to the resistor.
So right now I'm at dual pink under + side of coil and distributor wire should be at - side of coil, but I have no fire and neither of the pinks are hot with the ignition on.
