Re: 67 Corvette Wiper Motor Will Not Park
Hi Don.
You put 12V to the center lug only. The motor is hot all the time. Grounding one and then both of the outer terminals to gives you LO and HIGH speeds. We "bench tested" it on the car, and it wouldn't work.
We also tested the wiring to the switch.. and all of the contacts produced a ground connection as you rotated it. So, in our case, it isn't the switch.
My buddy is going to contact the rebuilder and see if he can send it back to him for repair.
Hi Don.
