GM # 3933819; Help with spare tire lock bolt dimensions - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
  • Russ S.
    • April 30, 1982
    • 2161
    Re: GM # 3933819; Help with spare tire lock bolt dimensions
    Original one on my 73 is 7 1/2 OA with 3 inch threads
      Russ and Gary-------
      I agree.
      By the way, while the GM #3933819 was used for 1968-74 Corvettes, it is also SERVICE for 1963-67.
      • Gary B.
        • February 1, 1997
        • 6979
        Thanks guys.
        Joe, do you have any idea which Corvette tire lock bolt would be have an o
          Originally posted by Gary Beaupre (28818)
          Thanks guys.
          Joe, do you have any idea which Corvette tire lock bolt would be have an overall length of 8.75” and a thread length of 4 3/16”? I have a used bolt with those dimensions and it doesn't match anything in my research notes.
          Gary
          Gary-------
          Assuming it's actually a Corvette bolt, I believe it's the 1978-82 bolt, GM #471903. This bolt is longer to accommodate the 255-60-15 tires optionally available for these years and it has a longer thread length to allow more adjustability when used with the 225-70-15 standard tires. I have NOS examples of this bolt but I really can't get at one right now to confirm.
          • Gary B.
            • February 1, 1997
            • 6979
            Joe,
            I have an NOS example of a GM #471903 and the overall length is 8.75", but the thread length is 5 3/16".
            Could the used bolt I have with the 4 3/16" thread length be a non-Corvette part?
            Gary
              • 15573
              Joe,
              Gary
              The only other application for the spare tire lock that I am aware of is Corvair, however I do not know what year(s) it would apply to.
              • Gary B.
                • February 1, 1997
                • 6979
                Terry,
                It's not a Corvair bolt, as I know the 2 or 3 bolts used on Conviar, which was a.completely different style of bolt.
                Gary
                • Alan D.
                  • January 1, 2005
                  • 2027
                  In light of a "one bolt services all" here is an original 3841464 used on a Mar64 car. May help to assume which spec's are
                  original. And some info from Sep 74 Parts Cat
                    Joe,
                    Gary
                    Gary------
                    The only other 1968-82 Corvette bolt is the GM #345476 used from 1975-77. I believe this bolt is longer than the 3933819 but I thought the thread length was about the same. Once again, I have NOS examples of this bolt but I really can't get at them to confirm.
                    The only other Corvette latch bolts were the GM #3841464 used for most 1963-67 and the GM #3872959 used for 1965-67 with goldline tires. The 3841464 was replaced by the 3933819 so I would think its dimensions were similar. The 3872959 I have no information on.
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      Here's a photo of the mystery bolt I have. I think it has to be a Corvette part.
                      Gary
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        Alan,
                        It looks like the threaded length on your bolt is less than 3.0", so clearly not the same as the one in my photo.
                        Gary
                          Gary
                          Gary-------
                          The only one I could see it being is the 78-82 GM #471903, albeit with a shorter thread length. It's possible the specs on that bolt changed at some time without a change of part number.
                          • Gary B.
                            • February 1, 1997
                            • 6979
                            Joe,
                            The mystery bolt and the NOS example of 471903 that I have are the same total length. Just the ratio of threaded to unthreaded lengths is different. I can't think of any alternative to an undocumented change, as you suggest.
                            Gary
                            • Joseph W.
                              • February 20, 2022
                              • 368
                              Mark for future reference
