C2 Emergency Brake / Parking Brake Pawls - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2126
    Do these pawls ever simply fall out? Is seems only the tension of the tiny two hole spring holds them against the handle shaft. Might they migrate out the right side?
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C2 Emergency Brake / Parking Brake Pawls
    Tom, They get installed before rod insertion via a slot on the other side of that photo so the rod keeps them from backing out. The only way they could come out is if the rod is removed.
    Rich
