1963 door window inner seal/wiskers - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    I am installing new seals on the door panels. The new ones came with no staples or holes for them. I assume there are no holes in the new ones because the old ones were attached using some sort of staple gun and locations of the staples were not precise. What is the best method to attach the new seals?
    Jeff
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 1963 door window inner seal/wiskers
    Jeff,
    The uppers on original 63 door panels are metal and they will have the original holes. You can find the holes and drill small holes in the whiskers and insert the staples. Then bend them with needle nose pliers to replicate the staple gun look. Al Knock and Auto Accessories can staple the seals in IF you bought from them.
    JR
