75 fender anti-theft switch - NCRS Discussion Boards
  • Richard R.
    • November 17, 2009
    • 76
    Can anyone tell me what the anti-theft switch located in front of the keyed alarm switch does? The reason I ask is the previous owner pulled the connector off and used a jumper wire between the 2 terminals inside the connector. I tested the switch and their is no continuity between the terminals unless the plunger on the side of the switch is depressed. The alarm presently does not work so I am sure their are other problems within the system. Their does not seem to be any write ups around that explain what the switches actual do. Also this car was an early 75 with the seatbelt interlock system which had been disabled so I don't if the alarm was part of this system also. I am stil trying to figure out how to put this system back together. Any help would be greatly appreciated.
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: 75 fender anti-theft switch
    Hi Richard,
    The seat belts don't have anything to do with the alarm system. There are three switches you'll need to check on for the alarm. One is under the hood at the rear on the passenger side. The other two are located in the lower rear door jambs. Once the key turns the alarm on, if either door or the hood is opened the alarm horn will sound with a pulsating low tone sound. The alarm horn is located up under the left rear fender below the antenna. The alarm relay switch should be located in the passenger side storage compartment under the jack tray. You should try to find the wiring schematic for the 75. It will help you a great deal. Here are a couple pics showing the 75 wiring diagram with the alarm wiring. Hope this helps.
    Happy New Year!🎈
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • Russ S.
      • April 30, 1982
      • 2161
      There is no such switch. If you are talking about a switch mounted in the fender it would have been added by a PO.
      • Harmon C.
        • August 31, 1994
        • 3228
        Their is a switch, if someone tampers with the back side of the switch located in the left fender the alarm will sound.
        Lyle
        • Jimmy P.
          • June 24, 2014
          • 1695
          Hi Lyle,
          Let me first start by wishing you a Happy NewYear!
          Is this the switch in question? (Part #1 in photo from Willcox)?
          Jimmy
          1973 Convertible
          L48,M20,N40
          • Michael W.
            • April 1, 1997
            • 4290
            Originally posted by Jimmy Patitucci (60161)
            Hi Lyle,
            Is this the switch in question? (Part #1 in photo from Wilcox)?
            That's the correct anti-tamper switch. From the OP's description it's operating in the reverse manner from normal. The switch should show continuity when the plunger is released not depressed.
            • Russ S.
              • April 30, 1982
              • 2161
              That switch wouldn't be located in front of the key switch. It would be behind it,in the inner fender.
              • Harmon C.
                • August 31, 1994
                • 3228
                The alarm is not in the inter fender it's just behind the fender in easy reach that is why it has a extra switch to set the alarm off besides the key switch.
                Lyle
                • Richard R.
                  • November 17, 2009
                  • 76
                  Thanks for the diagram, that is the switch! Now I see it suppose to be mounted. I am missing the slide plate and serrated washer on the bottom side. The previous owner could hold it against the keyed switch without those 2 items so he used the jumper wire instead to create the circuit mentioned in another thread.
                  Thanks to everyone for their help, now I understand how it works and how it needs to be installed.
