I am in the process of doing a full nut and bolt NCRS restoration to a 1970 LT1. In the judging manual it states that around serial number 14,000 the ignition sheilding changed and I have figured out that my car had the later style one piece ignition shield because my two orange brackets only have one nut welded to the inside. My question is should I have all four spark plug shields or only the two rear shields??? The judging manual is not clear on this. There are four inner shields of which I have all four originals, but I do not have any of the chrome outer spark plug shields. My car is 13,238. Thanks John.
1970 Ignition & Spark Plug Shielding
- Top
Re: 1970 Ignition & Spark Plug Shielding
Interesting stuff. Why did the General feel there wasn't a need for the two forward chrome shields?- Top
Because they began using a RFI (Radio Frequency Interference) shield inside the distributor. This RFI shield prevented most of the electronic "noise" from the points opening and closing from interfering with the radio.Terry- Top
I am not convinced any of that stuff was needed, points or not. I have friends who use solid core spark plug wires and no shielding and the radio works as well as expected until a spark plug or wire goes bad. Back in the day most of that chrome was removed at the first spark plug change. That is why so few cars have their original shielding.
I am surprised Chevrolet didn't eliminate it all as a cost saving measure. They seemed to nickel and dime every other part and system.Terry- Top
