Looking for info on starter 1108781 - NCRS Discussion Boards
    • 6940
    What does this starter no. fit, removed from a 66 corvette. 1108781 was stamped on side.??
  • Michael J.
    • January 27, 2009
    • 7073
    Re: Looking for info on starter 1108781
    The TIM&JG does not show that number for SB or BB starters in 1966. I show it for '71-'82.
      Edward------
      Late 1975 through 1976 truck with 350, 400, or 454 cid engine.
      Most likely, this starter went through a commercial rebuilding operation and all that remains of the original starter is the frame (i.e. the part with the stamped numbers). Starter frames (and MANY other starter components) are interchangeable among MANY GM applications (and, even some non-GM applications).
        • 6940
        Mike, Joe thanks for the info. into the junk pile it goes.
          Edward------
          While the number is not correct for any Corvette or, likely, any other collector vehicle, the starter might be otherwise configurationally correct for certain Corvettes and it's probably 100% functional for someone that doesn't care about "numbers".
