66 l36 oil pan - NCRS Discussion Boards
66 l36 oil pan
  • Greg W.
    • February 26, 2015
    • 141
    66 l36 oil pan
    In putting back together the oil pan I do not remember seeing an O ring or a seal on the dip stick tube where it meets the tube going into the pan. It did not seem to be that tight of a fit, Did I miss something or is there nothing there .
    Thanks for the help.
    Greg
    Re: 66 l36 oil pan
    Greg
    Greg------
    There's supposed to be a seal there. I've seen these seals as both a conventional style o-ring and a "square" cross section o-ring (like small block valve stem seals). I think either one will work fine.
