1963 door panel whiskers - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    I have already broken two small drills trying to install staples in the whiskers/door panel. Any ideas of how to do this will be appreciated.
    Jeff
    • 11608
    Re: 1963 door panel whiskers
    I used a small awl for a 71, but you could also use a small nail or similar. Those are cheap to replace and usually come with hundreds in a box.
    Obviously, use wood as a backer underneath it.
    • Bob R.
      • June 30, 2002
      • 1595
      I was able to use the 1/16" drill bit just go slow and let the cutting tip on the bit do the work.
      • Chuck G.
        • May 31, 1982
        • 2029
        Jeff
        Better quality drill bits and less muscle.
        It takes patience.
        • Frank D.
          • December 27, 2007
          • 2703
          It takes patience.
          Yup. If you 'lean into it' you're gonna snap those thin bits, I don't care what they are made out of...a little light oil can help with the cutting...
          • Jeff C.
            • 233
            Thanks for the help!
            Jeff
