64 gas gauge needle goes left when brake pedal applied - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2395
    Is this a grounding problem somewhere?
    • 6940
    Re: 64 gas gauge needle goes left when brake pedal applied
    John some movement was normal on midyears, the tanks were not baffled very well and the gasoline tends to make the gauge move around over bumps and cornering. I have the same issue with my 63 and tried everything, including cleaning ground at tank.
    • John F.
      • March 23, 2008
      • 2395
      Ed, this is with the car sitting still. You press on the brake and the needle goes left.
      • Stephen L.
        • May 31, 1984
        • 3148
        How far does the needle deflect......
          • 6940
          John check the ground at tank sender (they get rusty), maybe sourcing a nearby ground from the rear brake light bulbs. I have seen strange things happen with corvette grounds. Also check the brake lights rear and make sure there are all lite the same brightness.
          • Roy S.
            Past National Judging Chairman & Concours Team ******
            • July 31, 1979
            • 1022
            I believe you will find the gauge is not actually functioning because of poor ground, until you depress the brake pedal and it is then as mentioned earlier receiving a ground through the brake light circuit. Does the gauge read a 1/2 tank regardless of the amount of fuel in the tank?
            • John F.
              • March 23, 2008
              • 2395
              Roy, Stays on 1/2 full and then goes left.
                • 6940
                john, let us know how you make out. thanks Ed
