Oil leak - NCRS Discussion Boards
Oil leak
  • Ron R.
    • May 31, 1993
    • 190
    Oil leak
    2000 vette, 35,000 miles, regular oil changes. Went into garage the other day to discover a puddle of looked to be oil. The drip appeared to start dripping about a few inches from the oil filter towards the drivers side. The oil(I think) is crystal clear, ran from the front of car to the back of car.
    Any help is appreciated
    Ron
    • 6940
    Re: Oil leak
    Ron maybe post a pic. of the area.
    • Ron R.
      • May 31, 1993
      • 190
      Re: Oil leak
      I now believe it to be antifreeze
        • 6940
        Re: Oil leak
        Ron, common anti leaks are generally related to the water pump seal and gaskets on the LS motor's
        • Carl N.
          • April 30, 1984
          • 592
          Re: Oil leak
          Suggest you determine what the fluid is then look for source. This may be condensation from A/C system as it is engaged even when in heater mode. Also a leak in exhaust system can cause condensate. Last of all was car recently vwashed or in rain. There are several areas around windshield on C5 that hold water.
          • Steven B.
            • April 11, 2012
            • 233
            Re: Oil leak
            Just out of curiosity, is the compressor always on or does it cycle?
              • 6940
              Re: Oil leak
              Steve, when a/c or Defrost is on the compressor will cycle on and off it uses a pressure switch that can cycle compressor depending on outside temp. as the pressure varies the hotter or colder it is outside.
