Hi,
I am putting a GM 350/290 hp crate engine (GM #12499529) in my 1963. I am using a stock tach drive distributor instead of HEI. To round out the picture, I am using an Edelbrock Performer 2102 intake, 1968 style Q-jet carb and 1968 style air cleaner/PCV system. Hoping for help with the following questions:
1. The crate engine instructions recommend AC Delco #R45TS spark plugs and an HEI system for this engine. Would the AC R45TS plugs be appropriate to use with this engine set-up with a traditional distributor?
2. Are there special requirements for spark plug wires, distributor cap, points, rotor, etc. with this set-up or should I use what would typically be used on the base mid 1960s 327 or late 1960s 350?
3. Would a 180 degree F. thermostat be the best option for this set-up?
4. Which oil filter adapter would be best for this engine? oil filter bypass?
5. The crate engine installation instructions recommend an AC Delco CV774C PVC valve? Does this make sense with Q-jet and 1968 style air cleaner/PCV system?
Rob
Rob
