63 Ash Tray Door Knobs - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
  • Keith W.
    • June 30, 1998
    • 375
    Re: 63 Ash Tray Door Knobs
    Smooth. 110293
      • 6940
      my 110674 is smooth not far off from Keith's number
      • Jace H.
        • April 1, 1997
        • 253
        How do you remove those knobs? I need to do that.
        Jace
          • 6940
          Jace, the knobs are peened over on the under side, generally you drill or dremel tool and grid away carefully. you will need to remove console.
          • Bob W.
            • December 1, 1977
            • 799
            smoth 6895 vin Jan 15 1963 car.
            • Ed S.
              • August 6, 2014
              • 1377
              I did a small modification to a new ash tray door knob (purchased from Paragon) for my '64 which allows me to remove the chrome knob without destroying the two nipples. Actually, I replaced the nipples with threaded screws - now, if I remove the console I can remove 2 small screws and reuse the same handle. I wrote a short (not all that technical) tech article for the MAC Signal Seeker a while ago - copy attached, along with 2 pictures.
              Ed
              • Bob W.
                • December 1, 1977
                • 799
                ED nice article thank you for sharing it.
                • Keith W.
                  • June 30, 1998
                  • 375
                  Rear of door one screw crew and a couple of weal Ali rivets
