c1 Door Window Replacement - NCRS Discussion Boards
  • Ed P.
    • August 10, 2014
    • 89
    Please help, I tried all afternoon trying to take out the window from the door on my 1962. Help! Are there any videos or instructions available showing the removable of the window? Please
  • Thomas H.
    • August 31, 2005
    • 1053
    Re: c1 Door Windo Replacement
    The ST-12 manual has a procedure for window removal, installation and adjustment.
    If you don't have one, you can google it as there are several places online that have the ST-12 in pdf format.
    Tom
    2007 Z06, Lemans Blue
    • Ed P.
      • August 10, 2014
      • 89
      that was fast. THANK YOU i am gona look now
      • Don H.
        • December 1, 1981
        • 1482
        You can buy a copy from the NCRS store - a must have! Don H.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Re: c1 Door Window Replacement
          Ed, Definitely buy a hardcopy, but for now.....
          However, I find it easier to raise the window and remove the rear channel first. ST-12 says to remove the window first. This gives you more wiggle room later to get the window out after you lower the window to remove the 4 small screws from the lower sash channel.
          ST-12 procedure also doesn't tell you about the rubber outer sash gutter that gives grief, or about how much of a PITA it is to get it back IN the door and the fun to get the forward outer roller in the channel. It's a trial and error to get these done so just go slow and you'll find the sweet spot.
          In your other post , it never got answered, but attached below is how I do it. And other things you may find useful after you get the window out.
          Rich
          • Bob W.
            • December 1, 1977
            • 799
            Richard I think it is time you start The Richard Mozzetta Corvette Restoration Guide web page. You are so helpfull and the photos are great.
            THANK YOU FOR ALL YOU DO
            Bob
            • Ed P.
              • August 10, 2014
              • 89
              Thank you all. You have been a great help. Now i have too go and see if i can get the window out. The car is not at my house, it is in my son's garage. As for the ST-12 manual, i am gona print it off the computer. Richard the attached files that u posted, I can not download them. I got the rear channels out already. Richard can you email them to me if i give you my email?
              tanks again
              EDD
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                tanks again
                EDD
                Yes, send me a email through the Messaging system and I can email them to you.
                Rich
                P.S. Bob, Thanks...I had a website but Comcast deleted it.
                • Ed P.
                  • August 10, 2014
                  • 89
                  Richard i do not know how to send messages, I never done that. Maybe u send me the message and i will answer?
                  EDD
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    EDD
                    Ed, I am away from home so unable to access my server. Maybe someone else can send you a email with the files attached. I can't do that easily from this smartphone I'm on.
                    Rich
                    PS. If you double-click on each file attached it should open for view or print. Or "right-click" on each file attached it should show a drop down menu, then "left-click" ...."Save As". Or a similar way depending on which computer you're using.
                    • Ed P.
                      • August 10, 2014
                      • 89
                      Don what is the exact name of the book i have to buy from the NCRS store?
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11302
                        Ed, Just sent you a email with the 3 pdf's.
                        The name of the book is: 1953 - 1962 Corvette Servicing Guide ST-12
                        You probably cannot find it in the NCRS Store, because it is nowhere to be found. I can't find it anywhere.
                        Probably send a note to David King .......... shopkeeper@ncrs.org
                        ...or (513) 760-6277 EST please. from 9:00 AM to 5:00 PM EST, Monday through Friday.
