1958 tach drive mounting bolts - NCRS Discussion Boards
  • Howard H.
    • January 10, 2007
    • 133
    Does anyone know what head markings were used to mount the tach drive unit to the generator for a 58? One of mine has a small "L" on the edge of the head but am not sure it is correct.
    Thanks in advance for your help.
    Howard Hiller
  • Pat H.
    • December 1, 1996
    • 418
    Re: 1958 tach drive mounting bolts
    Howard, Most of the ones I've seen judging have been plain head bolts, however, if it has a small "L" at the circumference, then it's a period correct bolt and should not take any deduction.
    • Howard H.
      • January 10, 2007
      • 133
      Thanks Pat; it looks like it could be original to the unit.
      Howard
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Most I have seen same as Pat's. No markings, some with a tiny character, but probably all Grade 3 as there is no shear stress in that assembly.
        • Howard H.
          • January 10, 2007
          • 133
          It is a really tiny character, even with a magnifying lens, no other markings. Finish is gone so may not be worth using.
