Does any one have a MOOG 8282B or AC Delco 45F0022 Kingpin set for 53-62 Corvette/49-54 Chevy? If so, can you check what manufacturer and part number are the kingpin bearings supplied? I decided to save a couple bucks and got a "Restorers Choice" Kingpin set and the parts must be Chinese made, because the bearings are too thick and I can't get them installed. I don't think it's going to save me any money in the end. I'm hoping a good American made bearing will do the trick without having to spend another $60 on another Kingpin set.
I have original bearings "3003 Hoover Ball & Bearing Co." but cannot find any information on what the current part number is and the Hoover site doesn't mention them either sadly. These are about .559 inch thick, whereas the Chinese ones are about .575. I don't want to reuse them since they grind a bit when spun. I tried finding an interchange for the GM part number 373476 and there were lots of bearings and manufacturers, but I couldn't find any of them available...
And one of those was loose in the bore. So either my bore is oversize, or the bushings are shabby as well. I'll repress the MOOG bushings and hopefully they are all tight
