Duke, Williams,
A very long treatise on oil, found at www.540ratblog.wordpress.com with much self congratulatory back patting by author was brought to my attention. The author(name?) claims to be a mechanical engineer. He states he has tested 100's of motor oils for wear protection, using film strength load carrying capacity as criteria at ALS Tribiology in Sparks Nevada. He concludes that the need for ZDDY to prevent wear in a flat tappet engine with sliding friction to contend with is a myth. I don't buy this. I began using Rotella T in 1999 after reading an article in Nov 1999 Car and Driver where Ed Kollin, previously a research chemist in engine testing for Exxon, recommended diesel oil as best for collector cars. He did touch on need for ZDDP as an anti wear additive but his main point for diesel oil was for its anti corrsion protection in collector cars that sit for long periods without running. I have also read your article on oils many times.
I ask that you read and give your thoughts on "rat 540's " article I would also like for you to give the actual engineering tests that show the need for a reasonable amount of ZDDP to protect against wear so we'll have ammunition to refute the aforementioned "test."Thanks
