1965 muncie and bell-housing ID - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1575
    until dad orders the 65 manual can you guys help me with his trans from his new 65 L76 project. the bell-housing (not pictured) is a 621. is that correct? the trans I can't find the vin stamp. and thinking it was replaced along the way. also why is there a pound sign (#) under the word General?
  • Keith B.
    • 1575
    Re: 1965 muncie and bell-housing ID
    also here is the picture showing the POP with the P0203 for the trans
    • Jim D.
      • 2882
      Bellhousing should be #3858403. The VIN should be stamped on the opposite side of the P1203.
      • Keith B.
        • 1575
        Thanks, that is what I thought.
          Keith------
          No 1965 Corvette ever originally used the GM #3899621 bellhousing. In fact, that bellhousing was not even released until the 1967 model year.
          The original bellhousing would have been a 3858403 or, possibly, 3840383
          • Wayne M.
            • March 1, 1980
            • 6414
            A previous 365hp air car that I owned for 36 years, #014xx, had the ...383.
            • Jim D.
              • 2882
              It's generally accepted that some very early 65's, like yours, may have had the ...383 bellhousing carried over from the 64 model year. The OP's car was built approx. 4 months after yours. Regardless, the one he has now is incorrect.
              • Keith B.
                • 1575
                I think we all can agree I need to find a 403 bell-housing. What about the trans. Would you guys agree it's a over the counter replacment M21? What about the pound sign?
                  Keith------
                  GM #3858403 bellhousings are easy to find and usually not too expensive.
                  The transmission is a 1965 model year trans. The "P1203" stamping appears to have been done with individual stamping dies. It's curious, though, that "P0302" appears on the booklet. Possibly, someone tried to duplicate that and added one character. It's also possible that the main case was replaced and someone stamped this sequence on it.
                  • David B.
                    • March 1, 1980
                    • 687
                    Tag # 3857579 indicates: 1st gear 2:20, 2nd gear 1:64, 3rd gear 1:28, reverse 2:27 trans has: clutch gear 3831766, counter gear 3831727, Speedometer drive gear 3708145, Should have: 1-2 shift lever 3864402, 3-4 shift lever 3864403, reverse lever 3846891
                    The stamped letter P indicates Muncie built 4 spd Passenger
                    • Keith B.
                      • 1575
                      David Thanks a lot
                      • Andy C.
                        • April 1, 1998
                        • 117
                        Keith is there a Vin# on the opposite side of the date on the transmission?
                        • Andy C.
                          • April 1, 1998
                          • 117
                          Keith - I just looked at a pic of my 1965 Trans date. It is stamped the same way. Do not count that out as being the original trans for that car. Do some further investigation.
                          • Keith B.
                            • 1575
                            That's good question. I will have to degrease that side and look.
                            • Jim D.
                              • 2882
                              These are the stamps on one of my 65's.
