Tilt/Telescope horn question - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1879
    Hello All,
    I need some help with the horn on the T&T steering column on my '69. How many shims are needed under the upper contact assembly? Or maybe the better question is how do you know how many are needed? The AIM does not give any guidance- it just shows one. The issue is that the ground, when the horn button is pressed, is weak except in a couple of places around the circumference. The horns make a bleating noise except in those places. I know that the horns are good as is the horn relay. I think it has something to do with the horn button, upper contact, or the amount of shims I now have in there. Any help is very much appreciated.
    Jeff
