Home stretch on my 66 big block 3 1/2 year project. Front coil spring dilemma. I took it down the street for a short test drive and the passenger side coil spring got hung up on the upper tower. the driver side is centered perfectly. Coil spring work is no fun at all. I took the spring out AGAIN thinking I had it turned in the slot incorrectly I have tried it every which way and even flipped it over. I cant get it to not bind on the upper tower front edge. Is there a way to adjust the location of the lower control arm it seems if I could rotate it back and a bit inboard it would work. any other thoughts? Im stuck! on a part of the restoration I hate. THanks
