Hey guys, quick question. I have an unrestored 65 vert and have spent the last couple years trying to get the few items that were incorrect replaced with correct parts with correct dates, ie, alternator, carb, water pump, etc. Here's my question, the original washer bag is still in place, but I can see a small split in one of the seams and figure it most likely isn't water tight. I also haven't checked the washer pump which I feel certain would need rebuilding.
So, in an attempt to keep the car as original as possible, would you suggest leaving the original washer bag even though it isn't water tight, or, replace it with a correct new replacement ? Also, as I understand it, judges will accept original parts on a car and not deduct points for parts that are original to the car, but, in this case, it would be impossible to check the washer pump since the "original" washer bag won't hold fluid ??????? How is this handled in the judging world ?
JC
JC
