There is supposed to be a ground strap connected somewhere on the sill plate, one end with a screw and the other with a clip. I can't figure out the connection point. Any suggestions or AIM page references are greatly appreciated.
Ground strap location, '65 with side exhaust
Tags: None
- Top
Re: Ground strap location, '65 with side exhaust
Ok, that's the picture that came with the set of straps. Problem is, I can't figure out what I'm looking at. Is that at the forward end of the driver's side doorsill?- Top
Here's a pic. of the strap with the body removed. The clip at the end of the strap goes onto the birdcage sill plate. It's the same with or without side exhaust.
Attached Files- Top
Thanks Jim. I'll get up underneath and see if I can see the hole in the forward body mount. That is the driver's side, correct?
So I guess the difference in grounding on N14 cars is that there's no strap where the exhaust clamp would be, at the crossmember?- Top
Thanks Don and Jim - with your help I got the little devil installed.- Top
